Discuss Copper pipe sleeve through walls? in the Australia area at PlumbersForums.net
macka09
Hey guys. I know we sleeve copper pipes through walls to protect the pipe but what is the reaction called when copper is in contact with the brick mortar or plaster? Debating with a colleague. He thinks it’s elecrtolisys
Copper generally will only react with concrete / mortar / brick if the substrate contains high levels of sulphur ( most cements and mortars are low sulphur). In the presence of water that may produce Copper Sulphide - which appears as black spots on the surface of the pipe.
Electrolysis of copper is the school boy experiment to convert impure copper to pure copper - I don’t think it is used commercially, nor does it occur in the as built environment as it can with say zinc.
Don't those electro-osmo damp proofing systems (controversial, maybe snake oil) sometimes cause electrolytic corrosion in copper pipework? I seem to remember reading that somewhere and because of that, and the lack of proven effectiveness of electro-osmosis systems, they sometimes do more harm than good?
There used to be a myth that cement reacted with copper eg in concrete floors and thats why pipe was wrapped etc. Copper pipes laid bare into concrete etc. do end up leaking because they expand and contract and pull themselves apart . Wrapping them allows this movement . centralheatking
Reply to Copper pipe sleeve through walls? in the Australia area at PlumbersForums.net
