Discuss Copper US 1/2L to UK 15mm solder ring straight reducer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Andrew Parsons
Does anyone know where I can get a Copper US size 1/2L to UK 15mm solder ring straight reducer in the UK? I need to convert a US pipe size to a UK size, and I can’t find one anywhere. It’s for a gin still, so needs to be copper and not plastic.
U.S 1/2"L is 0.625" outer dia = 15.875mm
That should fit into a 15mm Yorks Capilliary fitting maybe with just a bit of fettling. Just as old U.K 1/2" does.
Alternately a 15mm /compression fitting maybe with copper olives, that'll stretch.
Try BES gas controls Electric Ave Brum, look in the refrigeration section, it is poss to build up solder and wipe it up....I have but a connection is best. Rob Foster aka centralheatking
Reply to Copper US 1/2L to UK 15mm solder ring straight reducer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
