Discuss Corvec Brittony II Multipoint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a Corvec Brittony II multipoint that will only ignite the main burners if the temperature control knob on the front of the multipoint is turned up to its maximum heat setting - making the water too hot to use. Do you know what the problem could be?
Ok 2 yr ago so it is not due a full service for another year then, Did you have the basic service done last year? I would still have a full service carried out by your local GSR as it sounds like it needs one & they could also see if anything else is wrong while they are there. I do suspect what is wrong with it but am not willing to share this due to people trying to have a go themselves at mending their own gas appliances by reading these threads. Not saying you would be that daft though. Hence the advice to have a full service done as what I think it is will be changed on a full service.
Thanks Darren, hopefully it is not a major component/problem then. Are you in the Kent area and if so what would be your charge for a full service.
Good advice from the guys above ^^^ , be aware some parts are getting hard to get hold of for these mulipoints , don’t throw a lot of money at it , it maybe time to change it depending on its age .
Reply to Corvec Brittony II Multipoint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
