Discuss Council bathroom fitting in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
Anyone worked for the council installing bathrooms/kitchens possible adaptations?
I used to do dis adaptations
There ok problem is some of the houses you can guess but others were fantastic
On average it was 3 days per bathroom
Yes they normally sub out the gas side as it’s too much hassle we’ll ours council did
I did it for I would say 6 ish years
And yes but depending on floor solid concrete yes akw tuff into floor but if byson beams / pre cast no going into the floor tray ontop and chase out for pumped drain etc
Did you like it? I think maybe in the long term I may get bord just fitting bathrooms
Yes and no depends on the clients let’s say old mrs Jones would do them day in day out and be greatful
Then you get the others just take take take
Can imagine there pretty labour intensive work. The tenent just managed in this time scale with no showering facilities? They didn't move the tenent out?
Depends on what was being done whole bathroom sometimes they moved but most just had to manage and you have to keep the toilet operating which was a pain
Did you just do adaptations for the council Shaun? I took a job with them been with them for about 10 weeks. I'm finding the work terribly boring.
Yes it’s repetitive yes but that’s plumbing in general tbh
Money ok ?
Yes I prefer the heating side. It's so so. It's the package with the pension and holidays. There plumbers scale is 32-35k. I was on 36k before as a gas safe plumber. I was hopeful of moving over to the gas side later. I think long term I would like to do heat pumps though. I have been on a few manufacturers courses.
Reply to Council bathroom fitting in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Does anyone know a good, not super expensive, leak detection company in the London area?
