Discuss Council bathroom fitting in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I used to do dis adaptations
There ok problem is some of the houses you can guess but others were fantastic
On average it was 3 days per bathroom
Yes they normally sub out the gas side as it’s too much hassle we’ll ours council did
I did it for I would say 6 ish years
And yes but depending on floor solid concrete yes akw tuff into floor but if byson beams / pre cast no going into the floor tray ontop and chase out for pumped drain etc
Reply to Council bathroom fitting in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
