Discuss Cutting copper pipe against wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, i need to make a tee section in a copper pipe for new hot/cold runs, however the pipes are against the wall and i cant get my pipe cutter all the way round. What's the best course of action?
See pic attached.
Grinder with one of these
http://www.NoLinkingToThis/p/titan-...tracking url&gclid=CIC-0M7r4tECFQs4GwodfRkF1A
Anyone remember or use the Rothenburger tool that would form a tee in copper pipe ??
Re. Rothenberger branch former. I've used the REMS one, but only very occasionally. Also the branch needs to be brazed in, not soft soldered, and that close to a wall the extra temperature would a) scorch the wall, b) probably wreck the joints below.
Could use a wire hacksaw like Silverline Wire Hand Saw 330mm
Reply to Cutting copper pipe against wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
