Discuss DANGEROUS gas leak, help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jay-seven
hi all, just need some advice?
my parents (who are now retired) bought a cooker/hob from a well know retailer, they came to install it, must of been about 4.30 when they finished, later that night as my parents were off to bed, they could smell gas, after calling british gas, they quickly sent someone to have a look, he was shocked that the cooker wasnt connect properly, in his words ( the gas was ****ing out) he fixed the problem.
the next day my parents went to the retailer to complain, they said, what do you want us to do about it and said you will have to contact the people who fitted it, THE PEOPLE THEY SENT TO FIT IT.
What should we do next?
this was very dangerous, we were lucky. but what about the next time they fit someones cooker?????
JAY
if the gas was not installed correctly then you can report to CORGI, HSE, and complete a RIDDOR form. The gas supply pipe should have had a tightness test performed on it after the installation (performed at the meter to check for leaks). Speak with corgi and they will give you any further advice
thanks, i'll contact corgi first thing monday.
i have just asked my parents about any test at the meter, they dont remember any test getting done, as the meter is in a small cupboard under the stairs, they did say the guy who installed it phoned his boss to ask would it be ok for him to connect cooker/hob up.
A gas connection pipe has to be registered with corgi for now, gas safety in april..
so they should have had a corgi number to register the appliance,,if not then they are illegal installers and want reporting....did you get their name/s....
will check if my parents got the names.
they where sent by a well known retailer?
notify corgi immediatly monday morning it sounds like the retailer is using non registered /qualified installers and will now be fined hopefully and prevented from putting lives at risk for the sake of saving money 60-80 is the going rate for installing gas appliance like a hob or cooker so they are prob using an illegal contractor
The company that installed the cooker/hob are registed with corgi. the guy who installed it said he was corgi registered (no card was shown) but my parents said they just expected him to be corgi registered because they bought the cooker/hob from a well known retailer.
after installing the cooker/hob does a safety certificate have to be issued?????
thanks again for your replys
I know that the appliance has to registered with corgi....not sure if you get issued with a copy.....never had gas appliance fitted...
Hopefully one of the gas lads on here can confirm that for you..
tightness test(gas leak test) should be done BEFORE any work is done. a new cooker could be plugged straight into a bayonet fitting in theory,BUT, they usually need a hose connecting to them. you are required to be corgi registered to fit this hose but NOT to plug into a bayonet fitting. after the hose has been fitted and plugged into the bayonet fitting ANOTHER tightness test should be done. if the firm supplying the cooker are providing a fitting service THEY are responsible to ensure that the installers are registered. your parents are also responsible to ensure this but taking their age into consideration( no offence intended) that could be disregarded. corgi should be notified first thing monday morning. they will need all contact numbers of the firm you bought from and the installer. the appliance does need registering but they have two weeks to do it in. to go into more detail checks should also be done on any other gas appliances to see if the newly installed affects them or is affected by their operation too. there is more to it than just banging a replacement cooker in.
they rang corgi monday, they have to send them all the details of what happened and the details of the retailer/installer.
they also rang the retailer main office, who said they were not happy about what happened to my parents and said that they will look into it and get back to them.
they rang back today and offered my parents there installation fee back £89,
my parents were fuming,
i,ve been following this one, and have to disagree with the tightness test theory, you only have to do a test if you are breaking into a gas supply ,before and after. The unplugging of a bayonet fitting does not count as breaking into a gas pipe,but you should leak detcet fom bayonet to cooker.there will be more of a danger if a safety bracket or chain has not been fitted. as affecting other appliances goes its got to be doubtful but a purist will allways find a check that can be done. good luckwith it all
disagree, well sort of, since a bayonet can be removed without tools ie a cust can do it then yes does not need tightness test but when was the last time you installed a cooker with the flexi hose pre-attatched, I've always had to install the hose so that requires tools and since payment is given to the worker for installing the cooker that constitues 'installing an appliance' and 'work' per gas regs so a tightness test should be performed pre and post work. Would be curious to see outcome of this though it is a pretty basic cock-up as you said even if they would have LDF'd it then that would have shown the leak instantly, even after I do a tight test i still throw a quick bit of LDF on just for completeness.
Reply to DANGEROUS gas leak, help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
