Discuss Database Errors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SimonG
Subscribed
Keep seeing the above when posting.
So u need a reboot or new lap top, cheapest way and best plumbers advice, send £60 to me at ..... for more advice:smilielol5:
Happens to me a lot as well.I clean out the cache and it seems to help until it fills up again. Mines is a modern core i5 lappy, so it's not the machine.
i get that as well
If it gets really bad, I clear everything....cookies,history, the entire cache but keep saved passwords, and it seems to help. I suspect though its really to do with the SVQ database on the server.
Something ain`t quite right for mine either regards turnpin:6:
We're working on getting it resolved please bare with and if all else fails hold hands and start singing christmas carols to keep morale up
Cheers BOD , did notice something weird happening with Mentioned stat , 0 was not always in right place ,
varied from member to member !
Reply to Database Errors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has been fluctuating quite alot, dropping in temp then raising again whilst showering. I have had an engineer out who has changed the thermistor, but I am...
Hello Wondering if anyone can offer any clues please // Potterton Promax 18 // Had an E1 error code, repressurised via with filling loop // Boiler fires but now the pressure runs up from 1.5 mark in the green up to 2.5 in the red then flicks off. // Error code again // Once held in reset for...
J
I have a 24kw combi Daikin boiler and it keeps sending up an error which according to the manual indicates the "pilot is out" any ideas? it often just comes back on, but it is happening relatively regularly
JulieWuli
J
R
Hi, The outlet of all my radiators are at 55°C, but the boiler keep showing the Return Temperature is 60°C (and keep raising at 1°C/min rate) Also the flow temperature keeps going up above the set point and when it reaches +5°C above the set point, the boiler shuts down (even before the room...
Renato
R
Hiya fellow gas engineer. Need some help on this boiler fault. Went out to this E133 Error on a Potterton Titanium 24 (GC: 47-393-39) I checked the inlet standing pressure which was at 25mb. Boiler attempts to fire and the pressure drops by 1mb but the gas valve doesn't open. Checked the black...
