Discuss dials on tankless gas geyser in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone,
What does the summer/winter dial do on a tank less gas geyser? Should you adjust it or leave it on one mode or adjust it according to seasons?
Any info would be great thanks.
Winter will warm the water up a bit hotter due to lower incoming temp eg 5dc
Leave it on what you want as already stated it’s to take into account the difference between winter incoming cold water being a lot lower temperature than summer. Old one used to be a water throttle so just slowed flow rate, new ones probably use thermistor to control temp
Reply to dials on tankless gas geyser in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
