Discuss Digital or electric shower in the USA area at PlumbersForums.net
I need advice on whether I should get a digital or electric shower. The water pressure in my flat is very poor for the shower (gravity fed water system, heated via HIU, on a district heating system), I’m on the 3rd floor (top floor) so it’s to be expected.
I know an electric shower would boost the water pressure for a shower significantly but would a digital shower do the same? I’m currently looking at Aqualisa’s range of digital showers, there are some suited for a gravity fed system but I’m unsure if this would boost the water pressure for a shower.
Reply to Digital or electric shower in the USA area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
