Discuss Dirty water, some ideas please.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Afternoon all.
Just been rent called to a friends rental property as tenant is complaining of discoloured water in the bathroom basin (only). Having re-run the gas pipes in copper from iron for this flat I assumed that the bathroom fitter had left a small section of iron pipe in situ and this is what is causing it. There are no loft tanks or similar as flat is run from a combi.
I spent a good hour looking under floorboards in what is a very small flat but no iron. I am now at a bit of a loss as to what could be causing the discolouration. Any thoughts would as ever be gratefully received.
Cheers
Matt
Ps ignore rent in first sentence no idea where that's from
work on water main outside, give it a good flush through to clear any disturbed crud?
Cheers lame. I did think along those lines it's only at the bathroom basin. ??? Weird???
Reply to Dirty water, some ideas please.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi all, Excuse the length but this seems like a complicated fix. I lived in a 1930s block of flats. Brick building with concrete slab floors...
2K
Hi, I took off the aerator on my bathroom sink. When I put it back on, it caused problems. When I turn on the water with the aerator in place, the...
1K
