Discuss Distance between wall and radiator? in the UK Plumbers Forums area at PlumbersForums.net
Hello everybody! I have a question: I have replaced old radiator(was leaking) using brackets from old radiator, it seems to me that radiator is too close to the wall. Please see pictures attached. Question is: is it acceptable to leave it like that? or there should be some rules for how much space there should be? New radiator i hanged came with no brackets as i bought second hand one but good condition. There is Brand new radiator downstairs, it has distance 10mm from the wall.
This is how close radiator is:
IMG_20221002_164059.jpgIMG_20221002_164122.jpgIMG_20221002_164136.jpgIMG_20221002_164529.jpg
This is the brackets i have use:
This is how much space brand new radiator have that came with brackets.
P.s Can someone tell me what brand that radiator is and what is suitable brackets i can buy for it if old brackets are not good.
Thank you for you help guys.
10-15mm depending on if you use the short or long and yes it matters as you won’t get good heat output from the rad
If radiator that flush with the wall is 600 x 1100, what the distance should be? Also can anybody identify brand of this radiator(i think its Wolseley CenterRad Compact) and suggest what brackets would be suitable?
I found Universal brackets on Ebay that are 3 Quid, also found Center Rad Brackets from Wolseley Website.
Thank you!
Either long side is 15mm more than the short side projection eg turning the brackets
It looks like your reused brackets can’t be turned (short/long).
Just get something to pack it. Cut a strip of 12mm ply the same length/width of bracket and put it between wall/bracket.
Yes they should be
Reply to Distance between wall and radiator? in the UK Plumbers Forums area at PlumbersForums.net
