david williams
define competent,every one defines it differently,even our courts cant decide.having every qualification in the book does not make you competent.
Discuss DIY Gas Fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there looking for a bit of advice spent many years working for a heating company and had relevant gas qualifications to do my job CCN1 CEN1. For other reasons i retrained as an electrical engineer. Now obviously my qualifications have run out and I think only my CCN1 is in date.
What I am trying to ask is I want to put a combi boiler in my own home, I believe I am more than compotent to do so. just wondering how go about getting someone to commison it, will that need done? Or could that be part of a service. I am having nightmares over a jobsworth coming round and slating my work!!
I'm pretty wise to fitting a boiler and it's a pretty simple job job with 22mm gas supply, waste for condensate, flue hole already there. so obviously moneys tight and want to do it myself!
Anyone fancy keeping me right and telling me what I can and can't do. sorry if this has been asked a million times before!
the regs state you can install if competent to do so, if you feel you are competent and can justify yourself in court if the need arises then make your choice
This is not the full story. The regs do state if you are competent, from the Gas Regs...
PART B 3. (1) No Person shall carry out any work in relation to a gas fitting or gas storage vessel unless he is competent to do so.
BUT it goes on to say
PART B 3 (3) Without prejudice to the generality of paragraphs (1) and (2) above ... is a member of a class of persons approved for the time being by the health and saftey executive for the purposes of this paragraph.
To me, that's saying you have to be fully registered with gas safe (a way of proving you are in that class of persons approved) and have all other relevant qualifications (Part P, Part L, CENWAT, CPA1 [from April 2012 I believe?] (which ever ones you need for the job), etc) and have good practical experience.
I think you would have a hard time in court saying that you feel competent!
Just be careful you don't drop yourself in it & get a gas safe engineer in to do the work.
In regards to competency with gas an individual is only competent if they have been deemed competent by a governing body
Gas Installations in a individuals home if carried out by an unqualified homeowner are still classed as illegal installations but these would only come to light if there was a unsafe situation or incident.
Have you considered hanging the boiler your self,
Plumbing in the water bits (hot, cold, flow & return, condensate run, PRV tube) and having opened up the hole for the flue, get in a local RGI to finish it off at a reasonable price?
Tim
all the jobs you mention are jobs to be completed legally only by a gas safe engineer
Reply to DIY Gas Fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
