Hi, do brass female straight compression couplings always have a 'G' thread (BSPP thread / BSP Parallel thread)?
I ask this because it's likely that I will have to replace a failed water hammer arrestor on the cold feed pipe that leads into my combi boiler and the replacement arrestor that I have in mind to use has a male 'G' thread (rather than a male 'R' thread / BSPT thread / BSP Tapered thread). I understand that the female brass straight compression coupling that the arrestor will have to fit into will therefore need to have a 'G' thread too (and not an 'R' thread).
So, it is safe for me to assume that the brass female compression coupling will be a 'G' thread or could it just as likely be an 'R' thread?
Many thanks if you can advise.
