Discuss Do I chase the connections into a wall. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Dodger2303
Hi all.
I am in desperate need of a second opinion.
I have two pipes (hot and cold water) that once ran down from the bathroom above and round a corner to our sink. Previously they were in a box in but the wall they were boxed into has been removed and now we are left unsure what to do now.
The wall in question is an external corner wall. Solid double brick (no cavity) wall.
We are unsure what to do as we need corner connectors when the pipes reach the floor as well as a t junction to connect a supply pipe to our washing machine.
We obviously want the nicest look but I am very nervous of burying pipes with connections in a wall.
At the top there is an area where we could install an access point with shut of valves if needed.
We are trying to choose between
1 - chasing it all into the wall and covering with plasterboard.
2 - boxing it all in again to allow easier access to the pipes in the event of a leak
I wish I could also post a picture.
Any help greatly appreciated as we need to start work tomorrow.
Either is ok upto you tbh
Reply to Do I chase the connections into a wall. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I’m fitting a small basin on a floating countertop (30x40cm) and will be chasing the internal clinker block wall to around 100mm wide to accept a...
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
The soil pipe from my bathroom passes through the outside wall and into the roofspace above the adjacent single storey kitchen before dropping...
I apologise in advance that this might not make sense or be full of silly/obvious questions, but I am a novice at all this! We have recently...
2K
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to...
