Discuss Does anyone know how this happens in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ok thanks just seems wierd in such thick copper. I've had this one time before as well.Probably just a week/thin point in the copper.
I find it extremely strange.I had the exact same thing Tuesday evening on open vent fill pipe, I bet it’s been in about 30 years too, very strange
Lots of possible causes (Google it). It often said that copper pipe lasts 20-50 years.Pinhole leak in old thick copper cold pipe for no apparent reason. See middle of picture
There was nothing on the outside. I just don't get it.Could it be uncleared flux?
Sorry I was trying to quote what people are saying and it was problematic.What do you mean Quote malarkey?
Ohhh. That make absolute sense now.Sorry I was trying to quote what people are saying and it was problematic.
Had 3 in the last 2 weeks. Had not had any in ages before that.Had one a week ish ago was just full of flux
Love the image reminds me of Vegas. The bellagio or whatever it's called. Sound bloody awful from our perspective thoughI don;t know w'y it happened.
but about 10 years ago, I had done a conventional to combi swap. Tidying up and getting paid. waked in the kitchen and water was squirting up through the kitchen floor. It was a quite magnificent fountain display, what you would see in a municipal pond / fountain. Had to replace about 9M of hot water pipe.
Don't be put off Copper by that. It is more than likely an impurity in the Copper. It might not happen again. Don't worry about it.Maybe plastic from now on then. First time I'm actually thinking this!
Flowflex produce a really neat solder cap which fits over the leak.Turn water off, drain clip on with flux solder up simplePinhole leak in old thick copper cold pipe for no apparent reason. See middle of picture
It was Rhodesian copper tube, very thin walled and fragile. It does pinhole and when you work on it often developes leaks eleswhereI was told by an older and wiser plumber that back in the 60's / 70's cheap copper pipe was being imported from "Africa", possibly Nigeria.
He reckoned it pinholed after a few years, particularly where bends had been pulled.
Not true I am afraid, at least it hasn't been for many a long year.Not that uncommon see pinhole corrosion 2 or 3 times a year even had it on my own property!
Always understood it's part of manufacturing process copper tube is drawn out and has to be anealed every so many passes.
During this process very occasional a small piece is scale becomes embedded in internal tube wall . Tube is very thin at that point and hard water and as some stage small fountain!
I definitely need to get out more !!Maybe I need to get out more but I found that very interesting. Lots that rings true and lots of things which I know a lot of us do are clearly not best practice.
Food for thought.
I don’t think that is correct. It depends on wherther or not you are comparing current specification R250 or R290 copper tube with earlier specifications. I have just micrometered ( if that is a word ) pieces of 15mm copper from 1969, 1976 and a new piece of R290 from stock. The wall thicknesses are all within the band 0.7 to 1.1mm - admittedly only three samples, with the latter (1.1mm) being current material. R250 (half hard) would be 0.7mm plus or minus 10%
15mm is available in wall thicknesses that range from 0.5 mm to 1.5mm.
Retail stores tend to stock relatively thin-wall, types, typically 0.7mm or 0.8mm.
Specifying copper tube correctly is surprisingly complicated:
Shaun Cobbs has a point as excess flux can slowly rot a pipe from inside.
This gets my vote as a likely reason. Excess flux used on nearby fitting can settle onto interior surface of pipe and over the course of time the acid in the flux can corrode the pipe from the inside creating a pinhole.Could it be uncleared flux?
Reply to Does anyone know how this happens in the Plumbing Jobs | The Job-board area at PlumbersForums.net
