Discuss Does anyone........... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi lads,
I am wondering if anyone of you installs a filling loop underneath the boiler ? If so, what kind of filling loop are you using?
I am thinking of installing something like this as it won’t contaminate the drink8ng water at all because it’s totally separate.
Heating system filling stations - Gebr. Kemper GmbH + Co. KG
Not required also hope they don't have a leak
Right, for me personally isn’t over the top but that’s just my point of view
Don't be offended by the Over The Top comment.
I know of one on a church system near me and to be fair I thought it made sense.
The only thing I don't like about things being set to autofill is that it is not apparent when there is a leak.
I have installed 4" Honeywell Backflow prevention devices very similar to that and they are very good. I just don't personally agree with the use of them on Heating systems.
May not be required but we are way behind the rest of Europe due to our WRAS
Correct but a constant fill is against wasteful water regs as you will know
How does this constant fill ? It just acts as a filling loop but keeps the systems separate. There is no chance of backflow. It’s good quality in my opinion and should be installed ... perhaps a little less pricy
How does this constant fill ? It just acts as a filling loop but keeps the systems separate. There is no chance of backflow. It’s good quality in my opinion and should be installed . perhaps a little less pricy
its designed to, thats where this and a pressurisation unit differ the pr unit has a sensor that stops the unit if it fills over a pre set time and some even sound an alarm
on a standard house / property you only need a double check valve as its classed as a cat 3 risk
but commercially its a cat 4 risk hence the rpz valve and pi
Ok on commercial ron but usually built in on most domestic boilers now mate , but you a free to fit anything you think is needed . regards kop
Remember the RPZ also has to be certified annually too! Not cheap last time I looked...
Its an auto fill valve with an air gap built in. commercial use mostly
Time for a water regs course ron
We use automatic fill valves on all systems over here.
They do require a dual check valve installed upstream of them.
As for - if you have a leak - well the system will keep re-filling and cause more damage.
As far as I am concerned, the damage would be the same as cold or hot water supply leaking.
Most systems are installed so as not to leak.
Alright, so you just use stuff like this on commercial systems but not domestics?! We use them on both and it has to be installed.
That's an expensive piece of kit to have to fit to every installation. I may have been ripped off but the last RPZ valve I had to buy cost over £200! A bit expensive for a filling loop when a double check valve is all that's required by our regs (and a disconnectable hose linking the systems).
An RPZ valve alone can't work as an auto fill valve though, right? If it can is it set to only let water through from the mains if the pressure down stream drops below a set point?
I was under the impression that it was just a fancy verifiable check valve with a dump valve that opens in case of loss of mains pressure protecting the mains supply?
Maybe there is more to them than I understand?
The one in the link has a pressure reducing valve also
You like mocking me off all the time ? Does it give you a certain pleasure? It ain’t easy in a second language. If you want you can try a little german :)
Everything will come with time, no one fell from the sky and knew plumbing inside out. Let me tell you, you do mistakes too but perhaps you won’t mention them on here. None is flawless, as long as I am willing to learn and open for knew things I will be a decent plumber :) trust me
Don’t take it to heart Ron. We are all human.
Reply to Does anyone........... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
Does anyone know please what kind of fitting this is? I have hot cold wallmounted faucets for a bathroom basin. The original taps (pictured were not gripping and slipping around the pipe)I was told by a plumber that he couldn't find any similar taps with a fitting like this (some sort of...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating Not Working Normally. When I turn on the heating, it doesn’t start. However, I still receive hot water, suggesting the boiler does work in some...
Hi Everyone I wasn’t sure whether to post this in here or UFH but hopefully I’m posting this in the correct group. I’m in the throes of a full renovation and am currently designing the central heating system, I’m installing radiators (11 or 12 in total) and am going to run each rad from its...
This bath filler/overflow is supposed to turn to divert water flow to a shower above. It’s not clicking across anymore. Does anyone recognise it? Fitted in 2014. It was installed together with this Bristan inbuilt thermostatic controller.
Deleted member 120897
