Discuss Does this look right to you? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A local plumber fitted a new Worcester Bosch condensing boiler about 4 years ago.
He fitted the flue as shown in the picture.
I recently removed the basket guard to replace it as it had gone rusty. (Why aren't they all made of stainless steel?)
Should the flue outlet be pointing up in the air?
Will rainwater go inside and cause problems?
Should I turn it so it is angled downwards?
Thanks for any replies.
Nope that's fine, as it's a condensing boiler if there is any rain water that goes down the flue it's connected to the waste system (drain) via a white overflow pipe (you might be able to see this below the boiler on the inside of your house)
I would be more concerned how the prv has been terminated/ looks like it's been snapped off
Also looks like it's released some fluid (brown staining)
Apart from the stain, looks good to me,
ok and other than to stop it blowing flumes in your face no
Reply to Does this look right to you? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
