Discuss Does this system need a bypass valve ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Visited a friend's house after an extension has been built. Part of this was relocating the boiler and controls. The system was converted from a gravity fed hot water and pumped heating to an S Plan system.
They had said that they had a problem with the hot water heating when heating was requested and I had told them that it was probably the two port valve that was faulty.
On seeing the results , the plumber had now installed another two port valve and installed a pipe joining the system skipping the faulty 2 port valve. The plumber didn't decommission the faulty valve.
When looking , I noted that there was also no bypass valve installed after the pump.
Is the installation of a bypass valve needed for an S Plan ?
Thanks in advance
Reply to Does this system need a bypass valve ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
