Discuss Double Check Valve with isolator? in the DIY Plumbing Forum area at PlumbersForums.net
Does anyone know where I can get a DCV with an isolator that is WRAS approved?
I need one for an outside tap and have limited space so I could do with a combined item
thank you :)
Filling loop and bin the loop you can use nuts both sides etc
Eg R24 Filling Loop - Screwfix - https://www.NoLinkingToThis/p/r24-filling-loop/83905
Reply to Double Check Valve with isolator? in the DIY Plumbing Forum area at PlumbersForums.net
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
Can anyone please tell me where I might purchase a 90° bend 15mm x 22mm Isolating Valve Thanks and Regards. Hugh
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
Hey all, Looking for some advice. My mother recently had her boiler changed but in the process the water had to be turned on and off as you would...
Hi Anyone know of a pull out kitchen tap that has decent pressure? I have had low pressure from this tap for a number of years and it's not...
