Discuss Drainage gully question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andyl
Hi
I had a muppet of a builder come in and install the drainage as you can see from the pictures he installed it almost at an angle.
Can anyone recommend what I need to do to correct the installation and not have water splashed on the wall (which could cause damp in the future).
I thought about concreting the area, but as you can see from the pics the drainage bottle gully its not level so will need to level this out somehow before thinking about what surrounds I can put in place..
Extend the waste pipe through the grate.
Clue, the circles in the grate are there to show where to cut.
Hi Andyl
The waste pipe looks too close to the wall, Is it fitted with extended pipeclips?
It should stand 25mm off of the wall and run straight down into the gully via the cut out
Russ
Reply to Drainage gully question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
