Discuss drayton digistat 1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
justanyone
drayton digistat 1
the battery indicator is flashing low despite new batteries fitted can anyone advise please
have you tried another new set?
Thanks for that ,unfortunately this does not have any info on the problem but thanks anyway
if you tried new set of battery and light is still on have you tried re binding it to receiver?
Reply to drayton digistat 1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
