Discuss Drayton UP2 Dual Channel Programmer - CH not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sxkirby
Hi all - I just moved into a new house with a Drayton UP2 Dual Channel Programmer for CH and water. The hot water works fine, but no matter whether i switch the CH to boost or just On there is no heating... I can hear the boiler fire up when I boost or switch on the water, but nothing with CH. The boiler is Worcester Bosch and was installed less than 12 months ago. Any ideas?
zone valve?
the boiler works, so it is a control issue.
should be an easy fix.
welcome along
Hi
Im having exactly the same issue in a home just moved into.
Water is fine, but cannot get the heating working in any way that makes sense - timed function doesnt seem to produce heat at all, On function does sometimes.
Absolute beginner when it comes to stuff like this so any "dummy guide to.." type help would be greatly appreciated.
Nas
Please register with us then start a new thread to receive an answer to your question.
Reply to Drayton UP2 Dual Channel Programmer - CH not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
