Discuss Dripping tap. Can’t access cartridge. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a dripping bath tap. Seperate to the spout. Quarter turn level tap from the wall.
I need to change the cartridge as it’s dripping lots but can’t seem to work out how to remove the housing. Has this been installed badly behind the tiles?
In the second picture it looks like there are threads in the chrome part where it meets the brass valve body.
I'd say the chrome part will unscrew, revealing a nut on the cartridge, it may need the tile grout scraping away from it first.
Caution where actually unscrewing the cartridge in case the body isn't fixed to the backing, the pipework may move leaving you with a hidden leak.
Thank you.
Reply to Dripping tap. Can’t access cartridge. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
