Discuss Electric Boiler daily usage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chacal
What is the expected daily usage of an electric combi boiler?
I recently got a 12Kw combi boiler installed in a small 1 bedroom flat. It runs the central heating (3 radiators) and the hot water for the shower.
I can measure the consumption and it uses 50kw/day! This is a lot more than I anticipated. Previous setup with independent electric radiators in each room only used 20kw/day (30 in a very cold day).
Does that sound normal?
doesnt seem out the way (3.2kw an hour) but all depends how much you use it there not the best for efficiency etc
best to keep and eye on it and write down your daily figures
Reply to Electric Boiler daily usage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
