Discuss Electric Boiler daily usage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chacal
What is the expected daily usage of an electric combi boiler?
I recently got a 12Kw combi boiler installed in a small 1 bedroom flat. It runs the central heating (3 radiators) and the hot water for the shower.
I can measure the consumption and it uses 50kw/day! This is a lot more than I anticipated. Previous setup with independent electric radiators in each room only used 20kw/day (30 in a very cold day).
Does that sound normal?
doesnt seem out the way (3.2kw an hour) but all depends how much you use it there not the best for efficiency etc
best to keep and eye on it and write down your daily figures
Reply to Electric Boiler daily usage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am renovating a 2 bedroom flat that currently has no central heating and will rent out. Looking to the future I understand electric is best...
I have an oil boiler for the central heating. Some time ago it stopped working, and as it was during the summer I stupidly left it for quite a few...
Hi all This is only about my third/fourth post, so go easy. Also, I'm only an enthusiastic amateur, not a pro... I'm having issues with the...
2K
Hello, Not strictly plumbing, but need your advice nonetheless as I'm out of ideas. We have recently moved into newly renovated apartment...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
