Discuss Empty Water Tank In Attic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Richarp
Hi All,
i moved into a house a couple of years ago and have decided to board the loft.
I've found any empty water tank that must have been used before an immersion tank was installed but it's still connected to a pipe going into the wall.
Is it ok to remove the tank? If so, what should I do about the pipe?
Any advice gratefully received.
The pipe going out the wall is the over flow, if the tank is disconnected then cut it up with a hand saw and remove.
check any pipes arent live then cut them out and dispose of them.
Am I the only one removing the old tanks these days lol!!!? I always feel its a bit of a shortcut just leaving it up there just because its in the roof space...
if you cant get it through the hatch without cutting, most leave them up there
I always remove them and the wooden stolage.
I always tried to remove the metal cold water tanks.
Always struck me as funny that people would have a tank lying up in their attic for years
" because it is too big for the trap door! " and they often argued with me that it it won't come down. Never seemed to dawn on them that a 3ft long tank could be dropped downwards through most trap doors from its 2ft square end! :smile:
Very often the larger tanks don't fit through the loft hatch as some were done when the house was built. I see this quite often.
Hi All,
That pipe looks to be the overflow,
Just remove pipe and cut flush with outside wall then remove tank
or double check outside there are no elbows on it and pull the whole lot through
Reply to Empty Water Tank In Attic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
