Discuss Esbe valve installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
magicno1
hi
Does it matter which orientation on a 3 port Esbe valve is installed ie from a mono bloc heat pump to a hot water cylinder and underfloor manifold or can the head be placed to suit?
Many thanks
Depends is it a diverter?
Not sure if still relevant but the head can be placed to suit, you just need to move the white spindle to the correct orientation in the body before you place the head on in the mid position.
Reply to Esbe valve installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
