Discuss Extra pump on a combi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nvq level 3
Hi all, A customer has had a loft conversion and is wanting rads fitted. Currently had a Baxi duo tec 33kw fitted (not by my self) this boiler is situated in a cupboard under the stairs. There is around 4.5m to the top of the rad from the boiler I do think this should be effiecent to get the heat up there but was wondering what your thoughts maybe? has anybody fitted another pump on to a system like this? also would it be worth fitting a pipe stat so it doesn't pull from the rads below? Thanks Rob.
just do your pipe sizing correctly, check pump hd is sufficient, which I expect it will be and forget the pipe stat idea
wouldn't worry about it. more concerned about boiler under stairs and the building regs (fire proofing)
Yeah I think it will be fine getting what I need out of it but when I was thinking about it, it's something I've never seen on a system with a combi so was wondering if anybody has had to do this?
Reply to Extra pump on a combi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I wanted to ask is there a function to remove air from a Baxi duo tec combi 24 HE A. If there is can some one kindly tell me the...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
I am looking to replace an oldish boiler and hot tank with a combi boiler. The house dates from around 1968 and quite possibly the (copper) piping...
1K
