Discuss F+E tank with no vent in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dom brennan
hi i was just wondering if this is normal or it it was a mistake. the F+E tank never had a vent on it, we drained it down and it took 2 hours to get up and running. some of the air was coming though the cold feed to the primaries to the tank. I've had a look though my college books but can't find anything. thanks dom
22mm cold feed off the tank? Combined feed and vent. Bit unusual but allowed on certain boilers.
i don't really know much about this kind of things but if the pressure got to much it would usually go back into the F+E tank, so does it go into the Cold water storage cistern but wouldn't that contaminated the hot water
F&E is heating (primary)
Cold water storage is supplying your domestic hot water, via the cylinder, and cold tank fed outlets.
I assume the tank you are talking about is the f&e (smaller of the two tanks).
but the primary is the same water in the radiators so if that pressure got to high for some reason i would go into the cold water storage or would this never happen i tried asking my employer but he just said he doesn't know
No Dom when the heating gets warmer it expands back into the f&e tank back through the feed pipe.
Like Ted say's....the primary water in the rads will expand back into the the feed and expansion tank (smaller one) and isn't connected to the cold water storage tank (big one). So no chance of contamination.
Primatic cylinder is another thing to go into, but I don't come across very many.
Also, your employer probably does know, but is too busy to explain it, which is common. Hence why this forum is helpful.
Reply to F+E tank with no vent in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
