Discuss Female 15mm flexi taptail in the USA area at PlumbersForums.net
I’m replacing my kitchen tap. All seemed straightforward but old tap had female connector 15mm flexi taptail and new one seems to be 22mm. Tried B&Q and Screwfix but they only have male connecting hoses. Any advice?
Keep looking, hoses generally have a nut or push-fit connection on the pipe end these are female connectors ie the pipe goes inside.
I’m guessing you have a nut if so you need a 1/2-15mm male iron
It is highly unlikely that a kitchen tap is supplied with flexi tails that end in 22mm?
Can you post a picture of the tail and what you are trying to connect it to.
Reply to Female 15mm flexi taptail in the USA area at PlumbersForums.net
