Discuss Fernox TF1 drain valve won’t open in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi chaps, anyone had an issue with the fernox TF1 bottom drain valve ? Just gone to drain it for the 2nd time and it’s not opening fully - just getting a small drip. The spindle that you turn with the plastic cap just spins and spins, it doesn’t feel like it’s doing anything internally.
It’s only been on the system for 3 weeks...
Its blocked with sludge, sometimes a small screwdriver into the hole over a bucket or tub and rattle it around might clear it, or you may have to remove the filter and give it a blast through a tap.
does the spindle move as sometimes the cap / key rounds out?
Most likely partially blocked.
I just remove the lid (valves off first) and poke down through the valve with a screwdriver or piece of wire to start it flowing into a bucket
Reply to Fernox TF1 drain valve won’t open in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. My home's Rheem water heater is dripping from the drain valve. It is strange as it seems to sometimes spit out some water and then stop...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
Hi all, I have an issue with our shower's hot water. The shower is operated using two separate taps for cold and hot water. When the hot water tap...
Hi all, have a radiator in the hallway which has never worked. When I bled the radiators few days ago I checked the hallway one, and it appears to...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
