Discuss fga results in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stevetheplumber
Subscribed
its no secret that i realy dont understand fga readings, yes i know the action levels and i can compare what ive got to the manufacturers recomendations
but im seeing condensing vaillants that chuff out 180 ppm co and old turbomax non condensers in the 30/50 ppm i thought the new ones were supposed to be better
had a new vaillant with a vertical flue knocking out 130 ppm last week,today a 13 year old ideal classic at 37ppm
They belt out more co because the combustion is forced and cooled , older ones the combustion is at high temp and an abundance of air as it's negative pressure (combustion sucked out)?
Do an fga on a clean Myson Apollo bf. Co might not even register
Its the ratio between CO & CO2 which counts. These older appliances may have less CO but also less CO2 which results in similar ratio's.
it costs me to have a van thats low emissions and allowed in the lez and imfitting boilers that are worse than the old ones
But they're not. The CO reading from the Fga isn't the whole story. You need to look at the excess air as well. The total CO from the old BF boiler will possibly be higher. To get a true comparison you need to look at flue gas emissions versus gas burnt.
Reply to fga results in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
H
HRP123
H
Good day all, I would like to get some advise and perhaps the solution to the issues with my UFH system. We did install UFH in an entire house...
5K
  • Locked
hi guys been to service a vaillant today in an empty house, co2 levels fine in the 9's co and ppm were sky high, co over 3000 ive checked over...
  • Locked
I have learned a lot reading the forum and thought I should contribute back with my recent experience.I bought a 90 square meter 2 story row house...
2K
