Discuss Finally found leak in Glowworm ultracom 30cxi in the USA area at PlumbersForums.net
So I've had a leak in this boiler for approximately 6 months. I hired an engineer to resolve and he suggested replacing a large black valve (I forget the name). After having the valve replaced, the leak appeared again around a week later. I tried to monitor so I could identify where the water was coming from and after a few weeks, I finally found it. I've uploaded a video here, can anyone tell me what needs to be done to resolve this?
I was charged quite a lot for the valve replacement yet the problem remains.. what should I do now?
In my opinion you still need the services of a qualified engineer (gas safe in uk). If it’s not the diverter valve (black plastic thing) then get whoever replaced your valve back as it’s been misdiagnosed.
How much did you pay ?
UPDATE:
The initial plumber seems to all but disappeared after having tried to contact him. After several months of looking for the leak I believe I've actually found the real leak. He replaced a valve which turns out did not stop the leak. I've removed the first video and uploaded here:
Please can someone help me identify what work needs to be done?
Reply to Finally found leak in Glowworm ultracom 30cxi in the USA area at PlumbersForums.net
Hi all, Couple similar but not same threads - my plumber is coming back (again) to try to sort the seemingly intermittent leak on my Glowworm...
1K
Hi all, I was just posting on here to see if anyone has had anything similar or can point me in right direction… I have a Geberit concealed tank...
5K
Deleted member 120897
Hi everyone, I’m completely new here and just signed up. My Termet boiler has been leaking for a while, and I’ve been procrastinating honestly to...
1K
Hello All, Yes, another 'leaking cyclinder' question...I'd be grateful for your advice. Vented 90x45 cyclinder in loft. Connection in question...
1K
N
Thanks in advance for any advice. We have a Lefroy Brooks XO concealed thermostatic valve shower and Worcester Heatslave 20/25 combi oil fired...
1K
Nathalie
N
