Discuss firebiird combi 90 Oil fired in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jpb
HI all, I am having problems with the above boiler,the following fault occurs.Run the hot water for a bath and after 5 mins water goes luke warm.Put central heating for a bit and then run a bath there is no problem water stays hot.
Could be one of a few probs.
looking at your posts, you have had a few issues with this. Get a decent engineer to sort it.
As Chalked says. Need to be in front of a firebird. Treat yourself to somebody familiar to the beast.
Could be any number of things, I would check the check valves first. Failing that better get someone out thete are a lot of things that need checking
Reply to firebiird combi 90 Oil fired in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
A
Hi, I have Worcester combi boiler which has developed a 'fault' recently. When I switch the heating on, the fire in boiler starts for a second or...
Andy Jackson
A
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Evening All, Been having on and off issues with a Greenstar CDI classic Combi were the hot water is not heating up but only intermittently. Some...
