Currently reading:
firebiird combi 90 Oil fired
Discuss firebiird combi 90 Oil fired in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jpb
HI all, I am having problems with the above boiler,the following fault occurs.Run the hot water for a bath and after 5 mins water goes luke warm.Put central heating for a bit and then run a bath there is no problem water stays hot.
Could be one of a few probs.
looking at your posts, you have had a few issues with this. Get a decent engineer to sort it.
As Chalked says. Need to be in front of a firebird. Treat yourself to somebody familiar to the beast.
Could be any number of things, I would check the check valves first. Failing that better get someone out thete are a lot of things that need checking
Reply to firebiird combi 90 Oil fired in the Plumbing Jobs | The Job-board area at PlumbersForums.net
