Discuss Firebird riello rdb burner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
My burner keeps cutting out it will run for maybe an hour or longer then cuts out but when you hit the reset button it starts again and runs no problem for another period of time.
I can hear a slight crunchy sound possibly coming from the oil pump..
A few days ago there was a high pitch whining noise coming from the boiler. I have never changed a riello control box before. I have a old riello spare burner I can swap over the control box?
Simple as this, - turn oil off, remove oil pump and then refit burner and turn it on and off for a few seconds while listening carefully.
If you hear any roughness, the motor bearing are gone and need replaced.
If not, then oil pump is probably worn inside and if you really wanted to verify that, the pump can be taken apart to view the gears and drive pin.
How old is the pump? 8 or 10 year old very likely worn
Reply to Firebird riello rdb burner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
