Discuss first time i have fitted a Worcester boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
seems fine to me when you consider that most 30kw will pan out at 3.22
no have you worked it out on input,as i dont fit worcesters i dont know what service mode is its probably were the boiler would be set to carry out a fga
on the phone to Worcester when commissioning boiler every thing ok ? The only thing i can think of is his explanation of gross to nett
if its been worked out as input and come up as 27.8 kw its normal for a 24kw combi
Reply to first time i have fitted a Worcester boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
