Discuss Fitting European shower trap to 40mm waste pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi Everyone,
Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside diameter euro pipe size outlet. I need to attach it to a 40mm UK size waste pipe and would prefer to solvent weld it as the pipe will be under a tiled floor. Can someone please point me towards what adaptors I can buy to achieve this? I am nervous about using compression fittings given I will never be able to get at this joint once the room is finished.
Thanks,
Shower traps are nearly always compression I wouldn't worry too much just crack on
Take a look at Mcalpine multifit which is the purpose made fitting for transition from european pipe sizing. They will have the size you need and are the industry leader in compression waste products
Depending on what plastic that duravit is made from it may not even be solvent weldable. The other option is to put in a different waste fitting and send the duravit back
I’d use McAlpine Z28L which is 50mm to 2”; then use 2” solvent weld pipe which you can reduce down to 1 1/2” if you need to, but if not run it all in 2”and you’ll have no problems.
Thanks Ben-gee,
That's what I was thinking although I've found this:
which I was thinking of then using with a reducing pipe insert from a swimming pool company:
Cheers,
David
I’m not a fan of pushfit personally and prefer compression as I feel you are more in charge of it - if that makes sense, but either of the above would be fine.
Thanks Ben,
I ended up going with a McAlpine Euro 50mm to UK 2" adapter (compression fittings), a piece of 2" pipe and then a 2" (weld ) straight connector with a 2" to 40mm reducer (weld) which I can then connect to the 40mm welded waste. Phew!
Now, does anyone know an easy way to cut 40mm pipe that is disappearing down an eves gap of a roof (to exit on the outside wall)?! I'm not even sure if a junior hacksaw can fit across the pipe.
Cheers,
David
Inside cutting wheel with an arbor and a drill with a steady hand or a pipe slice for plastic
Reply to Fitting European shower trap to 40mm waste pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hi I'm currently doing the pre-planning for my next DIY project fitting a shower tray and enclosure from scratch. I'm confident of being able to...
I have bought a shower tray and it has an extra large hole for the waste trap. Its a cooke and lewis think its an eclips 1400 x 900 tray. The hole...
plumber has not fitted water supply pipes level to tiles in shower, one side is approx 5-7 mm out of line, can i fit some sort of extension to...
