Discuss plumber has not fitted water supply pipes level to tiles in shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
plumber has not fitted water supply pipes level to tiles in shower, one side is approx 5-7 mm out of line, can i fit some sort of extension to resolve?
Cranked S unions for showers should sort it. They are 1/2ā€ one end to, fit into what you have there, and 3/4ā€ the other end - to which you can attach any bar valve.
The cranked nature allows you to level up incorrect pipe heights or spacing.
Reply to plumber has not fitted water supply pipes level to tiles in shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
