Stuartmcb
I am about to replace the leaking indirect, vented hot tank in the domestic central heating system. I would like to fit a 125 Heatrea Sadia Megaflo tank in the non-pressurized system. The hot water supply is not pumped. Is this possible? Is a pump required? And if so where should it be fitted?
Two story house. Two pipe system. Pipe run from boiler to hot tank about 18m of 28/22mm copper piping.
Worcester oil fired boiler 75,000btu.
Stuart
Stuart
