Discuss Fittings and consumables for sale and a few bits and bobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nysk2008
Hi all,
Having a bit of a garage clearout and am selling the following either a job lot or seperate:
Flue
1 x multifit horizontal flue including elbow part number 5118489
110mm
2 x Grey solvent AAV
2 x 90 degree pan connector
1 x D/SW short bossed
1 x 90 degree
1 x 90 degree coupling
2 x 90 degree (1 end female solvent the other male rubber)
50mm & 43mm solvent
10 x 43mm 90 degree bend
9 x 43mm 45 degree bend
5 x 43mm 90 degree street
1 x 50mm equal tee
1 x 50mm 90 degree bend
1 x 43mm equal tee
1 x 50mm straight coupling
Brass
1 x 15mm comp gas cock
1 x 15mm comp x 1/2 male straight
1 x 15mm comp x 1/2 fem backplate
1 x 15mm or 22mm comp pressure reducing valve
2 x 22mm comp stopcock
7 x 15mm x 1/2 fem service valves
3 x 15mm comp single check valves
2 x 22mm comp lever valves
4 x 15mm straight washing machine valves
1 x 22mm x 15mm centre comp tee
3 x 22mm comp ball o fix
1 x 15mm comp caleffi aav
1 x 15mm comp 90 degree
4 x solder drain off's
Copper
35 x 22mm coupling
7 x 22mm street elbow
13 x 22mm elbow
3 x 22mm x 15mm centre tee
2 x 22mm tee
15 x 15mm street elbow
44 x 15mm coupling
33 x 15mm tee
7 x 15mm elbow
Pushfit (mix of JG and HEP)
7 x 22mm equal tee
6 x 22mm coupling
7 x 22mm elbow
12 x 15mm equal tee
13 x 15mm elbow
1 x 15mm coupling
1 x 22mm x 15mm centre tee
Loads of 15mm/22mm inserts
2 x JG 15mm x 1/2 fem
Consumables
5 x 500g unleaded solder
4 x 150m loctite 55
1 x 350g fry powerflux
Stuff
1 x fluidmaster pro 45b
1 x used pcb for ideal icos he12 (working fine)
1 x used head from mid position acuator with wiring (working fine)
Cheers
why sell it all, everything is useable and youll only have to buy it again?
I'll give you £50 all in for the brass, copper and consumables.
Reply to Fittings and consumables for sale and a few bits and bobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with elbows), the last cm before the open end is pretty much straight, but as a result of the bend it is not perfectly round. I mean it is pretty much...
1K
Hi guys. A couple of things. 1 am I better fabricating bends in 14 mm copper for my ch or are 90 degree elbows fine, ref flow, friction ect. 2 my ch boiler, non condensing is playing up, I can get hot water, but when heating is on pipes only get hot for 1st mtre or so? I can hear feel the...
  • Locked
Please Read Full Description/ I Am Manchester Based Plumbing And Heating Fittings/Materials/Consumables 1000's £££££££ Various Items(See List Below) Sold As Job Lot Items That Are Included Are :- 200 x 90° Elbow Bag of 25 25 x 22mm Solder Ring 90° Elbow 100 x 15mm Solder Ring 90º Elbow 50...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm. This question is for my own house setup. We are really fortunate to have a large house, about 5,000sqft in total over 3 floors. It was built around...
1K
H
HRP123
H
