Discuss Flexi-hose inlet to toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Phil
Is it classed as a 'bodge' or lazy to use an isolating flexi-hose for the water inlet to toilet cistern, I keep seeing these but I've never done it this way myself.
Thanks for any replys.
i don't like them myself think they look ugly.
providing you fit it with no nasty kinks in the flexi it will be ok.
I use them often with no problems. Rarely, a customer will say she doesn't want one and prefers copper piping. It's obviously a matter of taste! Most people don't concern themselves much with what goes on under the toilet cistern as long as it works! They've been used in most places on the continent for many years, and certainly do save time.
A technical advantage with a flexi-hose is that it does not subject the plastic inlet tail to any stresses that might make it leak or be difficult to get a watertight joint, especially if the tail is not quite aligned with the connector. Sometimes wc cisterns drop a bit (especially on modern ticky-tacky walls) which can put stresses on a rigid all-copper inlet joint.
A further advantage is that the sealing system provided with the flexi-hoses I use is much more reliable and easy to fit than the usual fibre washer on a rigid connector. This is especially true with the plastic valve inlet tails now common.
Reply to Flexi-hose inlet to toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
