Discuss FlexiSure Comp-Connector in Smaller Sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Lorfy
Does anyone know if you can get the below product in either 100mm or 200mm lengths. All the majors only seem to stock it in 300mm and 500m.
[DLMURL="http://www.diy.com/nav/fix/plumbing/plumbing-supplies/plumbing_fittings/-specificproducttype-connectors/PlumbSure-Flexi-Comp-Connector-15-x-15-x-500mm-11478193"]PlumbSure Flexi Comp Connector 15 x 15 x 500mm, 0000005272273[/DLMURL]
It is a female to female 15mm i'm after but 300mm is still a little too long.
Any known gems or specialists would be much appreciated.
Cheers
Cris
do it in copper, do it in copper, do it in copper..
orrrrrrrrrrrrrrrrrr......
Speedfit 1/2"bspx15mm flexible hose 150mm
fit a 15mm compression coupler onto the tap connector side of this to make it pushfit to compression - which will work in whatever circumstance you're trying to use compression x compression for.
Do it properly in copper, not a hose. It's only a short section. Round 2 of copper v's flexi coming up......
Reply to FlexiSure Comp-Connector in Smaller Sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
