Discuss Floorboard holesaws................ in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Are these any good for chipboard flooring?
Does the 'plug' fit flat so that you wont see it under carpets?
Seen many a new build floor riddled with them, plasterers shove up the boards and trap the wires between the underside of joists :D
Poor old sparks, has to free em
The hole and rebate is made with a special hole cutter that matches the plugs. There’s a smidge of a gap around the perimeter of the plug... but even linoleum would cover and not show through.
Normally fit the extra / plastic discs
Wouldn’t recommend for traffic areas unless you glue it down
Yep
Reply to Floorboard holesaws................ in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys I know this ain't plumbing. But some of you may know. I have a small bathroom but water seems to leak to the kitchen. I realised under...
There's a leak in the ceiling of my Dad's living room which is on the ground floor and has a bedroom directly above it...
  • Locked
Hi, I recently fitted a new central heating circuit and ran hot and cold to the bathroom and kitchen in my property (I was a CORGI registered...
Tray is stone cast resin low profile, 1200 by 900. Suspended floor is receiving all new 18mm P5 chipboard floorboards. There is plenty of talk of...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
