Discuss Flowflex in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kyle87
Worst brand I've ever came across!!
End feed elbows and couplings were like Russian roulette trying to find ones that fit the pipe.
Had two male irons to compression for the flexi tsp tails. Ended up peeing water everywhere. I normally use poofixes plumb sure brand for compression and soldered fittings and get on just fine
Flow flex is bloody awful!!
Noted. Has anyone else had this with Flowflex, or was this just a dodgy batch?
Hope you didn't buy too many of those fitting mate! :disappointed:
Flo Flex ANYTHING are the worst cheap junk you can use. The pushfit fittings leak, the soldered and end feed fittings have variable pipe diameters and the plastic stuff is so brittle that turn it sideaways and it will crack. Just a note about the soldered fittings, the solder has a very weak alloy and bits of it will run right through the pipework and get into showers and pumps and cause damage.
Best to spend a bit more on quality brands as the extra cost incurred will be saved by not having to go back and fix it!
1 bag of elbows, 1 bag of couplings and 2 compression/male irons.
That's all I used and will never touch the brand again!!!
EVER!!!
Reply to Flowflex in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi all Fitting a new monobloc mixer tap. The flexi tails that came with the tap (see first photo) don't fit the connection (see second photo). Is...
3K
  • Locked
Hi people, I am trying to do a basic plumbing installation, and would like some pointers, as i have never done any plumbing in my life, and i...
3K
plonkerplumber
A
  • Locked
I recently had a complete replacement central heating system installed (Worcester 28Ri). The work is of a good standard with 15mm copper pipework...
4K
lame plumber
L
  • Locked
As you know I have been doing some plumbing and started soldering for the first time, Iam pleased to announce that all my soldered joints were...
2K
glenno1
G
G
  • Locked
In the past 2 weeks, I've had 3 Fluidmaster fill valve failures. Stripping them down, their appears no apparent reason for this. I always twist...
3K
Veggie Dave
V
