  • Thread starter Steven Sluman
  • Start date
  • Replies 1
  • Views 2K
Discuss Flowmax Fm4651 v Flowmax 4734 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Steven Sluman
Hi does anyone know the difference between a Flowmax Fm4651 140ltr and a Flowmax Fm4734 140ltr combination cylinder and are they interchangeable or where I can check info
The Flowmax was originally made be "Range" cylinders of Wakefield , they were bought out by Kingspan a few years ago . The new flowmax's serial no's do not match yours , so they might be off a previous model , one major difference on the Flowmax ( sorry I dont know if this helps ) is some had manual fill and some were auto-fill . To help me why do you need to know ?
Reply to Flowmax Fm4651 v Flowmax 4734 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Does anyone know a good, not super expensive, leak detection company in the London area?
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
