Discuss Flu Error. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Too close to the wall also I beleive. Should be at lease 300mm right?
Some of them can be fitted as close as 25mm to adjacent walls/gutters/downpipes/eaves etc in accordance with MI's
Measured this evening. 120 from the wall. Less to the dowpipe. Logic tells me PC will enter the open window. Agree?
That'll only be on condensing units as the exhaust gases run much cooler, you'll generally find a caveat stating that only one 'reduced' clearance is allowable. This has at least two.
Its really not that big a deal. Most boilers I visit have atleast one thing that is NCS, flues are quite a common one. Aslong as there are no signs of distress or reports of fumes entering through the window, dont worry about it.
Reply to Flu Error. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
