Discuss flue gas analysis - too much O2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
Could I check I correctly understand fga readings taken off an old Microgenus combi.
The ratio is great (0.0003%). CO2 is only 3.4% (should be 7.62), O2 is 15% (should be closer to 7%, according to the boiler manual). CO was 33ppm.
The ratio passes the gas safe requirements.
However, the readings suggest the boiler is under-gassed. Solution: check incoming gas pressure to the boiler, and also the burner pressure (which I don't have - but let's assume it's low).
Would a low burner pressure would be cause for the boiler to fail the certificate?
Apparently, the gas rate was spot on. But surely it can't be - if the boiler isn't burning enough gas to use up all the oxygen.
Also, how much work would you do on a boiler if the landlord only wants the gas safety certificate? Ie, they don't want to spend money on having it cleaned, adjusted, etc, despite the engineer's better judgement. Or if a 5-yr burner seal is due renewal, but no visual damage? Obviously, if it fails the certificate, the work must be done (or the boiler condemned).
Thanks for your advice,
Jennie
Have you had your fga on LPG? Wouldn't be the first time I've done it!
Your readings are not quite correct. Is your analyser working and if so, did you pre purge it in fresh air?
Oh ... yeah, I did have it on LPG. I realised once I got home. How much does this change the readings?
The gas rate was good, the flame picture great.
Thought O2 should be 20.9 % not 7 % or am I reading things wrong
If inlet is within parameters, gas rating is good, seals intact, integrity 20.9% flame picture good then all should be well to pass. Just need to double check the FGA is set up for correct fuel n go back to get an accurate ratio to record on the CP12.
26(9) Minimum gas safety checks. Burner pressure/Gas rate where appropriate both.
lol delete post not getting into trouble fir posting in wrong place sorry
if this is a public forum, have the rules changed, all this should be in a private gsr forum surely
It should be done with an analyser that has a calibration certificate and also a trained engineer with CPA qualifications , but your readings are well within the regulation standards, youve also an excess air reading,
Reply to flue gas analysis - too much O2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I think was very... ambiguous... advice. 12yo boiler with the following readings on the analyser printout: O2% = 4.1 CO ppm = 192 CO2% = 9.5 Ratio =...
Morning all, I am just about to begin doing more installs of combi boilers, I am gas safe but just never really done a lot of installs due to being busy with general plumbing and bathrooms. One question that i have is, when checking working pressure on a boiler with a zero governor what sort...
I recently had a gas safety certificate check done by and my Vaillant Ecotec Pro24 boiler serviced/checked. However a month later and after taking a meter reading it showed that the amount used had nearly quadrupled since the previous month with no change in usage. Hot water is only set at 50...
Unable to adjust co2 readings on a a vaillant ecotec boiler it’s an lpg model I’m currently getting 0.0004 ratio, can’t get a higher co2 percentage than 8.6% (minimum being 9.7 without cover) and the ppm is around 40 Have tried new gas valve new Venturi and new pcb. I’ve cleaned burner and...
3K
Deleted member 120897
Hi guys So basically what happened is an engineer came out to my mums a week ago to do her annual gas safety check, shes a disabled bed bound OAP so on these occassions i have to go to the property to let the engineer in to do the job, she lives in a council property in London. So guy turns up...
3K
