Discuss Flue terminal new window in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bassmonster
Hello all,
I'm just in the middle of my ACS gas course. For some reason, i now have the habit of looking at flue terminals outside houses...:oops:. If a flue is less than 300mm from a window opening, would that mean the gas engineer has to disconnect the boiler and if customer does not give permission, they would have to be reported?
You would get an FGA and do a room CO test and if it stays under 10ppm its ok. with window fully open etc.
The full procedure and classification is in your unsafe situations book.
I would not have to much faith in relying on a co test a a lot depends on which way the wind is blowing ect bf or ff I tend to ar a bf to cover my own arse.
Exactly my thinking. My brain tells me to AR it at least!!
Reply to Flue terminal new window in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
I had a combi boiler put in my rental property about 10 years ago by a contractor arranged by the letting agency and I assume qualified. Gas...
Good afternoon, I was hoping someone could advise regarding the regulations around flue terminations through a 'fake' window. We have a...
2K
My installation has been classed as Dangerous 'Do not use' by my boiler manufacturer. I have an Ideal Logic 30kw Combi boiler mounted as high as...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has...
